16-inch x 60-inch Engine Lathe
The 16-inch x 60-inch engine lathe from Palmgren has the power to deal with heavy metal removal. It has the accuracy and control to handle precision fine tolerance turning.
August 25, 2017
Standard on the lathe are a DRO and glass scales for added operator convenience and accuracy. The lathe is ideal for turning applications that require heavy metal removal or fine tolerance finishing. They are used in toolrooms, die and mold shops, fabrication shops and maintenance departments.
