2 Rod “Auto-Cut” CNC Carbide Cut-Off Machine
The 2 Rod "Auto-Cut" CNC Carbide Cut-Off Machine automatically cuts carbide rod into precision lengths. This production machine, designed for cutting tool manufacturers and carbide rod processors, has a large-capacity magazine and an automatic loader to provide hours of unattended operation.
August 1, 2018
The 2 Rod "Auto-Cut" can double the production rate for cutting carbide and hardened steel rod when compared with manual cut-off machines. It has easy to use CNCs with a touch screen operator interface. Parameters can be quickly set for rod diameter and length. The machine automatically loads and cuts rods from a large capacity magazine. Capacity of the 2 Rod "Auto-Cut" is 0.079" (2mm) to 0.787" (20mm) diameter rod, up to 15¾" (400mm) long, or 0.079" to 1.575" for single rod, and comes standard with a flood coolant system.
