2D Laser processing machine
Mazak Optonics Corporation’s Lz Series -2D Laser Processing Machines from its new OPTONICS brand features higher power levels and table sizes that allows for the production of larger work pieces.
March 17, 2026
Features of the Lz Series include:
–Mazak SmoothCUT Technology: Available in 6.0 kW, 12.0 kW, and 20.0 kW, this advanced feature guarantees consistent and reliable beam quality across various materials and thicknesses, optimizing cutting performance and accuracy.
–Dual Pallet Changer: Minimize machine set up time and maximize efficiency with the ability to load/unload one pallet while cutting continues on the other.
–Machine Monitoring Cameras: Two monitoring cameras provide real-time progress checks during processing and setup, enhancing operator visibility and control.
–Dedicated Programming System: A user-friendly touch panel programming system simplifies workflow, reducing setup time and ensuring consistent, high-quality results.
To meet the diverse needs of modern manufacturing, the Lz Series is offered in a range of model sizes, starting with the Lz 3015A, which offers high-quality and accuracy when cutting thin to medium-thickness material and is ideal for compact floor space, and expands into the Lz 6025A with higher power levels and table sizes that allows for producing larger work pieces.
