3+3 Air Chuck
3+3 Air Chuck
Ideal to handle the harsh demands of the Oil and Gas industry, BB-FZA2G allows for quick and easy setup of odd shaped pipe for threading and re-threading. Thanks to incorporating three jaws with axial adjustment of the centering position while also using three compensating jaws with extra long rapid and clamping stroke of 1.5", there is no need to re-shim the part. This enhances operator safety and greatly increases overall productivity.
SMW Autoblok, a world leader in the design and manufacture of rotational chucks, stationary workholding, tooling and custom engineered solutions for the machine tool industry, presents the BB-FZA2G pneumatic 3+3 sequencing air chuck featuring an extended stroke clamping range and three self-centering jaws with axial adjustment.
Ideal for machining straight and bent pipe, BB-FZAG is available in 740, 800, and 920 mm to cover an extensive range of pipe diameter sizes, and features a large through hole of 275, 330, and 390 mm. This state-of-the-art sequence chuck with pressure control safety system greatly increases production output without re-shimmming of jaws.
