3859 Easy-Cut Xtreme Trimetal Bandsaw Blade
The 3859 Easy-Cut Xtreme Trimetal Bandsaw Blade cuts "easy to cut" materials and difficult materials with the same blade; there is no need to change blades. This saves time and money by reducing blade inventory, operator labor and machine downtime. The 3859 also boasts a much longer blade life than bimetal blades. Its enhanced durability also means the blade can cut faster when needed.
Bahco is expanding its bandsaw blade portfolio with the debut of the world's first trimetal bandsaw blade. The Bahco 3859 Easy-Cut Xtreme Trimetal Bandsaw Blade offers users an easier, wider-ranging and faster cut with a longer-lasting blade life.
Bahco is a world leader in the bandsaw market with more than 140 years of experience manufacturing saw blades and cutting tools. The company is renowned for its research and innovation efforts that ensure they stay ahead of the curve, which lead to the development of its new trimetal carbide bandsaw blade.
The 3859 can cut a much wider array of materials, including structural and mild steels, stainless steels, cast iron, high temperature alloys and tool steels. Its unique set pattern provides a greater range of cutting widths, bringing greater application potential and increased productivity.
Because the trimetal blade uses the same parameters as bimetal blades, there is no need to break in the blade. The 3859 comes direct from our factory already honed with a patented edge preparation. This is our best multi-application out-of-the-box bandsaw blade yet.
