4JIT Bullet Magnetic Separator
Industrial Magnetics Inc. announces a line extension of its Rare Earth Bullet Magnet called the 4JIT Bullet, designed for flexible-hose pneumatic line systems to improve product purity and protect processing machinery from tramp metal damage.
Consisting of a 100 percent stainless, two-part body, the BM4JIT's inlet and outlet is designed to install to a flexible hose system, allowing dry powder and granular materials to pass through the magnetic housing and be purified of metal contaminants. Access to the magnetic circuit is achieved by opening the tri-clover clamp on the housing and removing the lower body to clean collected tramp metal.
Because it installs to flexible line pneumatic systems, the BM4JIT is a portable and versatile magnetic solution and can be used ahead of processing equipment to protect machinery from tramp metal damage and at bulk load out zones to ensure product purity.
The 4JIT Bullet is designed to operate leak-free at up to 130 psi and is capable of operation in explosive environments. Standard design is available for 3", 4" and 5" line sizes, with custom options available upon request.
