5-axis hole deburring with hyperMILL
Open Mind Technologies has released a range of enhanced features and innovative technology in its hyperMILL 2025 CAD/CAM Software Suite.
May 1, 2025
Open Mind Technologies has released a range of enhanced features and innovative technology in its hyperMILL 2025 CAD/CAM Software Suite. Highly productive programming and machining strategies in hyperMILL enable accurate, efficient 2.5D, 3D, precision 5-axis and mill/turn machining.
The innovative 5-axis automatic tool orientation mode in hyperMILL 2025 ensures optimized machining, enabling efficient and reliable tool paths on the most complex components. The 5-axis automatic tool orientation mode algorithm uses a pre-analysis of the entire tool path to calculate machining sequences of simultaneous and indexed tool movements, reducing the number of inputs required for 5-axis machining and saving time when programming challenging parts.
A 5-axis hole deburring strategy excels at deburring sharp edges on holes and intersecting holes, the company says. By using CAM Plan programming assistance and analysis technology to automatically recognize all the holes, the sharp edges in the model are marked for selecting the desired edges. The hole deburring technology automatically calculates tool paths and supports 3-axis and 5-axis modes. Also, hyperMILL now offers a 5-axis deburring strategy for fast and efficient deburring of component edges. Users may choose between 3-axis machining and a 5-axis option which enables greater reach to more component edges, automatically generating the required inclinations as well as collision avoidance.
LinkingLinking with hyperMILL Dynamic Stock technology.">
The pocket milling algorithm for high feed cutters in hyperMILL 2025 has been redeveloped for 3D-optimized roughing, achieving greater efficiency during roughing as well as better machining control, especially helpful when machining large lateral in-feeds and remaining material. Contour and path radii can also be defined, resulting in improved toolpath rounding.
Linking movements via hyperMILL VIRTUAL Machining Optimizer have been further optimized for actual stock conditions with new Dynamic Stock technology. Using Dynamic Stock, an updated stock is automatically generated for all machining jobs and accounted for when calculating linking movements.
In addition, hyperMILL 2025 includes new technology such as a revised 5-axis Profile Milling cycle, a totally new 5-axis ISO Machining cycle, enhancements to turning postprocessors for main/ sub spindle applications on Siemens, Fanuc, and Mitsubishi (Mazak) controls, and more.
For more information about hyperMILL 2025, click here.
