5-axis MultiBlade Options
GibbsCAM announced availability of two new options for GibbsCAM specifically developed to simplify the 5-axis programming required to make turbomachinery parts.
GibbsCAM announced availability of two new options for GibbsCAM specifically developed to simplify the 5-axis programming required to make turbomachinery parts. The new options have user interfaces that are optimized for fast selection of geometry and toolpath parameters to program machining of impellers, blisks (bladed disks) and blings (bladed rings). These bladed parts, which are used in compressing gas and liquids, or transporting them under pressurized flow, are common components in the aerospace, automotive and power generation industries.
Each of the two new software options targets different levels of specialization and part complexity in bladed-part manufacturing. While 5-Axis MultiBlade Level 1 is designed for parts of simpler to moderate complexity, 5-Axis MultiBlade Level 2 increases the selectable toolpath options to accommodate the most complex bladed parts, which may have multiple smaller blades (known as splitters and sub-splitters) between the main blades. The GibbsCAM 5-Axis MultiBlade options operate within the GibbsCAM 5-Axis software, accommodate both 5-axis machining centers and multi-task machines, and are available immediately.
When added to GibbsCAM 5-Axis, MultiBlade Level 1 simplifies programming and machining of blisks, blings and impellers having single splitters or no splitters. Toolpath strategies include 5-axis simultaneous roughing, hub finishing, and blade and splitter finishing, with automatic gouge checking on all toolpaths. The interface includes options for leading- and trailing-edge extension and control, plus intelligent controls for rotating toolpaths around the part.
Roughing between blades with splitter support
Blade, splitter and hub finishing
Leading- and trailing-edge extension and control
Tool axis tilt controls
Toolpath axis rotations
Automatic axis detection
Automatic and user definable links and clearances
When added to Level 1, MultiBlade Level 2 provides incremental capabilities to simplify programming and machining of parts that have multiple splitters and/or sub-splitters. It adds a fillet machining strategy and provides additional control for all toolpath strategies.
Blade fillet finishing
Tool axis smoothing
Splitter smoothing
Multiple splitter support
More control for tilt, leading & trailing edges, and all toolpath strategies
Toolpath segment sorting
Stock definition for rest machining
In addition to simplifying and speeding up the programming process, the GibbsCAM 5-Axis MultiBlade options generate cleaner, more efficient toolpaths for faster machining, better surface finish, and higher quality parts.
