5-Axis Profilers
5-Axis Profilers
The compact 5-axis profilers from SNK America are designed to stand up to the rigorous demands of medium-sized to large aircraft components machining. Choose the model that meets your specific requirements: HPS B series for high-speed aluminum machining or the HPS A series for titanium and other hard metal machining.
Spindle heads provide high speed and power while generous A and C rotary axes allow for a wide range of 5-axis machining. The horizontal design allows for unrivaled chip evacuation and promotes longer tool life. Tilting table enables highly efficient machining and simplifies loading and unloading.
Features/Benefits:
■ Optimized axis-feed machine structure makes high feed rates possible
■ Features two wider-range rotary axes (A-axis: +/- 90⁰, C-axis: continuous rotation) allows for diverse 3D contour machining and reduces rewinding time
■ Automatic Pallet Changer (option) minimizes machine stop time contributing to enhanced productivity
■ Tilting Table Mechanism: chip removal efficiency is increased in the upright position, easier workpiece setup in the horizontal position
■ Fully enclosed splash guard provides clean environment and ensures worker safety
  • feed
