5-axis universal machining center
The GROB G150 5-Axis Universal Machining Center from Grob Systems Inc. is the company's smallest horizontal machining center in its modular G-series Universal line. According to the company, the G150 provides high precision, complex machining in a compact size with a smaller work envelope. Featuring direct and absolute position encoders in all axes and an innovative machine cooling process, the machining center provides exceptional contouring accuracy.
The GROB G150 is equipped with features that provide a wide range of benefits, including optimal chip evacuation via its horizontal spindle position, which permits the longest possible Z-travel path in its machine class. Three linear and two rotary axes enable five-sided machining and simultaneous interpolation.
The machine's axis arrangement makes overhead machining possible, offering operators optimum accessibility for a broad range of part sizes. Tool changes occur outside of the work area, which eliminates chip interference during tool changes. In addition, a tool brush cleans the tool shank prior to the tool being inserted into the spindle, and a coolant flushing system pushes chips out of the work area and through the conveyor.
