556 Series Constant Intensity Panel Mount Indicators
Dialight announced the launch of its 556 Series Constant Intensity Panel Mount Indicators, the company's first constant intensity product designed for rugged, outdoor applications. Combining InGaN and AlInGaP technologies, the 556 Series delivers maximum light output in a highly durable package designed for 1" mounting holes in applications ranging from instrument panels and agricultural controls to transportation, environmental monitoring equipment, display lighting and much more.
Dialight announced the launch of its 556 Series Constant Intensity Panel Mount Indicators, the company's first constant-intensity product designed for rugged, outdoor applications. Combining InGaN and AlInGaP technologies, the 556 Series delivers maximum light output in a highly durable package designed for 1" mounting holes in applications ranging from instrument panels and agricultural controls to transportation, environmental monitoring equipment, display lighting and much more.
Designed for reliable visibility, the 556 Series ensures continuous indication in battery-operated equipment that will not decline as voltage depletes. Built for rugged conditions, the 556 Series is IP66, NEMA 4X rated and RoHS compliant with 6C exemption.
The 556 Series is available in two options:
- Daylight viewable with a clear, flat UV-stabilized polycarbonate lens over a colored LED for even distribution of light and maximum visibility at any angle.
- Standard PMI, available with a flat or domed, tinted, polycarbonate lens over colored LEDs. The standard series is also IK07 certified for impact resistance.
Both are built to operate between 18-48-volt DC and at extreme operating temperatures ranging from -30° C to +85° C (22° F to +185° F). Each unit comes in red, green or yellow with a white or black nickel-plated brass housing and nut. Terminals are hot solder dip with 6-32 screw terminal connection.
"We've heard a lot of requests in the field for a constant-intensity product that delivers Dialight's signature reliability and durable construction," said Matthew Boudiette, Dialight vice president and general manager. "We're happy to oblige with this highly resilient product that's built to withstand the rigors of outdoor and industrial equipment. We aim to expand this line with a wider range of mounting hole sizes in the coming months."
