5918 Series Swiss ID Burnishing Tools
Swiss ID burnishing tools by Elliott Tool Technologies are ideal for accurate sizing, low microfinishing and surface hardening of ID holes down to 4 mm. With the tool body completely inside the tool block, the new 5918 series features an adjustment knob which protrudes from the rear of the tool shank, thus allowing the burnishing tool size to be adjusted for diameter without removal from the tool block.
Swiss ID burnishing tools by Elliott Tool Technologies are ideal for accurate sizing, low microfinishing and surface hardening of ID holes down to 4 mm. With the tool body completely inside the tool block, the new 5918 series features an adjustment knob which protrudes from the rear of the tool shank, thus allowing the burnishing tool size to be adjusted for diameter without removal from the tool block. This cost-effective, easy-to-use tooling from Monaghan Tooling Group improves surface irregularities and tool marks, producing optimal surface finishes of 4 to 8 Ra in a single pass. This proven technique can eliminate secondary processes such as grinding, honing and polishing by automating those processes in the primary CNC machine. Doing so saves setup and processing time and labor costs and also enhances machinery utilization and shop floor productivity.
Compact burnishing tools are ideal for applications where the machine working envelope is limited, as is found in most Swiss-type turning centers, small CNC turning centers and when burnishing parts in subspindles where the machine working envelope is reduced.
Burnishing is an ideal way to accurately hold diameter tolerances in "tenths" (0.0001") and produce microfinishes in the range of 2 to 8 Ra in most steels, stainless steel, aluminum and other metals that have a hardness of under 50 RHC. The new line of compact ID burnishing tools can be applied to a range of industries, such as medical, fuel systems, fluid power and small automotive components.
Economical, long-lasting and replaceable wear parts reduce the total cost over the life of the tool. Wear parts are easy to replace, with common tooling available from stock. Their operation and maintenance requires minimal training.
