6-Spindle Lathe
6-Spindle Lathe
ZPS America LLC's cam-driven 6-spindle automatic lathe has a 20mm bar capacity.
ZPS America LLC's cam-driven 6-spindle automatic lathe has a 20mm bar capacity. The rigid, European-built machine is for continuous or series production of precision turned parts. Solid base casting ensures maximum rigidity and stability, according to the company. The machine includes six frontal slides with up to 110 working strokes, and six cross slides plus four compound slides with clamping, and bar stop in the sixth station. An independent cam controls each slide. Stroke is adjustable on the rocker arm of the corresponding drive. Machines in the range are provided with different spindle speed ranges, depending on material type and size. Four safety clutches prevent the slides from overloading. Spindle drum locking is accomplished by a Hirth coupling for repeatability and precision. A bar stock guide is standard, and the machine can also include automatic bar loaders and bar magazines for long, unattended operation. Spindles are driven by Simodrive Siemens variable-speed motors and the machines are controlled through a Siemens S7. To accomplish nearly any operation, the machines can be provided with a wide range of optional equipment, including NC drive of the pickup spindle, bar stock feeding and clamping in the fourth station, attachments for high-speed drilling, reaming, tapping and broaching, and multispindle drilling heads on the frontal slides.
