670 Series LED Panel-Mount Indicators
Dialight launched its new high-visibility 670 series LED panel-mount indicators, providing a range of sizes and operating voltage in high-durability housings. Offering high-intensity daylight visibility hundreds of times brighter than its 600 series predecessor, the 670 series is ideal for main and remote power, status, maintenance, warning and instrumentation indication for front-panel mounting in hole sizes from 5mm to 16mm.
December 5, 2016
Dialight launched its new high-visibility 670 series LED panel-mount indicators, providing a range of sizes and operating voltage in high-durability housings. Offering high-intensity daylight visibility hundreds of times brighter than its 600 series predecessor, the 670 series is ideal for main and remote power, status, maintenance, warning and instrumentation indication for front-panel mounting in hole sizes from 5mm to 16mm. Products are available in 2, 3.3, 6, 12 and 24 VDC operating voltages (depending on model).
Each unit in the series consumes 90 percent less energy than equivalent incandescent indicators for substantial operating cost savings, and the RoHS compliant indicators are highly durable, tolerating ambient temperatures from -4° F to +167° F (-20° C to +75° C) and lasting up to 100,000 hours for exceptionally long-life performance. Two models, the 677 and 679, are water tight, carrying NEMA 4X and IP66 ratings with a metal housing for more robust applications.
Each indicator is backed by Dialight's 1-year full-performance warranty and comes with both solder terminals and wire leads for quick, plug-and-play installation.
