7792VXE16 Shell Mill
ATI Stellram has introduced the 7792VXE16 high-feed shell mill cutter for machining titanium and nickel- and cobalt-base alloys.
October 1, 2010
ATI Stellram has introduced the 7792VXE16 high-feed shell mill cutter for machining titanium and nickel- and cobalt-base alloys. The tools are for taking shallow DOCs at high feed rates, and they direct cutting forces axially into the spindle. That reduces spindle wear and enhances machining stability, which is beneficial for modern and older machine tools, the company reports. The cutters accept inserts with four cutting edges, including the company's grade X500, X400, SP6519 and SC3025 inserts.
