#8150 4.5" Diamond Grinding Wheel
January 10, 2017
Innovative Products of America (IPA) announces the #8150 4.5" diamond grinding wheel. The disc's innovative, 3D contour with topside abrasive coating and thin-profile edge allows for cutting, back cutting, gully cutting and bead finishing with one wheel.
The #8150 provides versatility with its highly durable, diamond, abrasive coating. The disc maintains its size and shape throughout its extremely long life, providing consistent reach and performance when dressing welds and accessing corners, according to the company.
"Compared to other grinding wheels, the 4.5" diamond grinding wheel provides a long-lasting, cleaner and faster cut, saving both time and cost. Depending upon the application, they will last between 20 and 60 times longer than the standard wheel," says Ian Vinci, vice president of IPA.
  • abrasive
    abrasive
  • dressing
    dressing
  • grinding
  • grinding wheel
    grinding wheel
