Machine shops looking for a “second-op” machine can depend on Palmgren’s vertical machining center for a compact solution. The 7-inch by 24.5-inch center is ideal for production lines, short runs, one-offs and prototyping.
Designed to fit into small spaces, the machining center’s rigid construction means improved accuracy and repeatability. The Siemens control, with its simple to use and easily intuitive interface, is configured for entry level operators.
- machining center
machining center
