#9684524 Engine Lathe
With the power to remove heavy metal, the 16- x 60-inch engine lathe from Palmgren also has the accuracy and control needed for precision fine tolerance turning. Standard features on the lathe include a DRO and glass scales for added operator convenience.
May 10, 2018
The headstock provides maximum power for rough cuts and smooth, quiet power for fine finishing. The #9684524 lathe, like all Palmgren lathes, is built and inspected to the DIN 86056 toolmakers precision lathe standard to assure accuracy and consistent performance.
