A590 Machining Center
The A590 is a 23,000-lb. cylinder head porting and block machining center for big billet and diesel work. Whether you need to port long V12 or diesel cylinder heads, have a large production volume of heads to port, or have a specialty application requiring extreme angles, the CENTROID A590 is suitable.
January 29, 2018
A heavy-duty, articulating 5th axis provides rigidity and speed. The A590 is big and heavy in every way, which enables the XL to handle big heads, steel heads, cast iron heads and serious production machining capabilities. Included in the A590 turnkey package is a starter tooling package, expert training, and customer service and support.
A590 Turnkey Engine Machining Package Includes:
  • Patented 5-axis CNC machine, 180 degree B-axis
  • M400 5-axis CNC
  • Mastercam 5-axis CNC software with Port Expert
  • Personalized CNC porting training
  • Digitizing probe and software
  • Starter Tooling package
  • Auto tool length setter
  • Cylinder head fixture plate
  • Toolholders
  • MPG electronic handwheel
    The A590 can port cylinder heads from a wide range of engine configurations: V12,V10, V8 heads, V6, Inline 6, 5 and 4 cylinders, import, motorcycle, gas and diesel engines. The A590 has the capacity to CNC port long cylinder heads such as inline 6 cylinder gas and diesel heads. CENTROID has simplified the porting process, now you can digitize a head in the morning and be cutting perfect copies in the afternoon.
  • machining center
