A60 and AG60 Inserts
Walter has introduced the new A60 and AG60 inserts for small to medium pitch threads. Just like the existing MX geometries (CF5 and GD8 for grooving and parting, RF5 for grooving and copy turning), the new MX geometries A60/AG60 provide long tool life, fine surface quality and process reliability. The inserts have four cutting edges.
The geometries are made for creating 60° partial-profile external threads in a wide range of pitches 6-48 TPI—threads per inch (0.5–3.0 mm) and are particularly suited to thread-turning in tight spaces, like near a shoulder or counter spindle. Because of the unique insert seat pockets, inserts with different thicknesses (size 2 or size 4), as well as different function (grooving or threading) can be used in the same holder. This enhances cost effectiveness and universality.
The Walter MX system is suitable for all materials and enables insert widths between 0.03-0.13 in. (0.8 and 3.25 mm) and cutting depths of up to 0.24 in. (6 mm). One special feature is the design of the insert seat. Due to its self-aligning tangential clamping, the insert is pressed against the contact points when the screw is tightened. A special dowel pin helps with accuracy of fit and simultaneously makes it impossible to mount the insert incorrectly. This results in a high degree of dimensional stability and repeat accuracy.
  • grooving
    grooving
  • parting
    parting
    When used in lathe or screw-machine operations, this process separates a completed part from chuck-held or collet-fed stock by means of a very narrow, flat-end cutting, or parting, tool.
  • pitch
    pitch
