![](/sites/default/files/styles/product_image/public/product_images/RexCut14766.jpg?itok=RwPaidlr)
A line of Type 1 cotton-fiber abrasive wheels for grinding, deburring, and polishing that reportedly last up to 10 times longer than unitized wheels is available from Rex-Cut Products.
Rex-Cut Type 1 Abrasive Wheels feature multiple layers of cotton-fiber with aluminum oxide or silicon carbide abrasives laminated, pressed, and bonded into a dense wheel that constantly exposes fresh abrasives while grinding. Comparable to 8 or 9 density coarse, medium, and fine unitized wheels, the cotton-fiber 54, 80, and 120 grit GFX bonded wheels grind faster, last up to 10 times longer, and provide an equivalent finish, claims the firm.
Available in 1" to 4" dia. sizes from 1⁄32" to ½" thick, Rex-Cut Type 1 Abrasive Wheels come in coarse, medium, fine, and very fine grits with soft or hard bonds and are ideally suited for use on aluminum, steel, stainless steel, titanium, Inconel, and other exotics. Applications include aircraft production, oil field pipe thread grinding, and field service repairs.
- abrasive
abrasive
- aluminum oxide
aluminum oxide
Aluminum oxide, also known as corundum, is used in grinding wheels. The chemical formula is Al2O3. Aluminum oxide is the base for ceramics, which are used in cutting tools for high-speed machining with light chip removal. Aluminum oxide is widely used as coating material applied to carbide substrates by chemical vapor deposition. Coated carbide inserts with Al2O3 layers withstand high cutting speeds, as well as abrasive and crater wear.
- grinding
- polishing
polishing
