Add-on Module to NCL Machining Software
NCCS Corp., developer of NCL multiple-axis machining software that is used extensively in the aerospace, automotive and turbo-machinery industries has further developed an add-on module to NCL for high-speed bulk material removal.
April 3, 2019
  • Increased performance, reduction in costs:
    • Shorter cycle times: as much as 3 to 1 (or more) over traditional milling.
    • Less wear on your machine.
    • Greater tool life
  • Efficient toolpaths for open shapes:
    • The programmer can cut any combination of part/stock boundaries easily; all open edges are fully leveraged for efficient machining and to minimize plunging into the material.
  • Intelligent slot milling and side milling options:
    • For softer metals the software provides the fastest possible cycle time and intelligently selects slot milling or side milling to maximize the material removal rate. Feed rates and axial depths of cut are automatically adjusted in slot milling to maintain a constant material-removal rate and can be overridden by the programmer. For harder materials users can configure side milling over the entire toolpath to avoid burying the cutter.
  • Fast machining of small pockets:
    • The program offers the fastest way to clear out small pockets, as well as efficient specialized tool motion for tight spaces.
  • High-feed repositioning with floor clearance:
    • The software fully leverages the machine's capabilities allowing the tool to move safely and as quickly as possible when not engaged in material.Additionally, it clears the floor by a small amount when repositioning at the highest possible speed without dragging it across an already-machined floor.
  • Automatic feedrate adjustment:
    • The programmer can maintain a more consistent load on the cutting tool with no feedrate optimizer needed; VoluMill toolpaths include precise and automatic feedrate optimization.
These key features of NCL will help companies get the most out of their software investment by increasing programming proficiency in addition to improving the quality and accuracy of their NC programs.
"NCCS is dedicated to constantly improving our software technology, giving the end user what they want," says Don Schultz, president of NCCS. "The latest release of NCL is yet another example of the entrepreneurial spirit that has made the company successful."
