Aero Clean SLC
Aero Clean SLC
Aero Clean SLC enhanced water-based cleaning products are available from Chemtool Inc.
Aero Clean SLC enhanced water-based cleaning products are available from Chemtool Inc. Aero Clean SLC is a water-based, pH neutral cleaner, that utilizes specialty surfactant systems for superb cleaning on all aluminum alloys as well as non-ferrous alloys and specialty ferrous alloys. Aero Clean SLC offers cleaning performance over a wide temperature range (room temperature to 180°F) and is highl effective at liberating and removing hydrocarbon oil based soils and contaminants from a variety of surfaces, according to the company.
Aero Clean SLC dilutions exhibit an ultra-low interfacial tension value which allows the cleaner to wet out and cover extremely fouled surfaces. This performance feature actually allows the surfactant technologies in Aero Clean SLC to effervesce contaminants immediately from the treated substrate without actually emulsifying the soils or contaminants. First and foremost, this unique performance property then allows the cleaner solution to pop-out and reject soils and contaminants to the surface of the cleaner solution. Soils and contaminants can then be quickly skimmed and separated from the cleaner solution, significantly enhancing cleaning performance and extending cleaner life alloys.
Aero Clean SLC Benefits:
High degree of cleanliness for worker acceptance and good housekeeping practices
Outstanding wetting and coverage properties on all alloys and complex part geometries
Halogen free
Suitable for both spray and immersion applications
Contains no caustic, inorganic, hydrocarbon oils, nitrites, silicates nor glycol ethers
Excellent rejection of soils and contaminants for prolonged fluid use life
Readily compatible with fluid recycling systems
Pratt & Whitney approved
Low V.O.C. value of only 2.0 grams/liter
Energy efficient cleaning allows for lower operating temperatures and shorter cycle times
