AG100L Sinker EDM
Sodick Inc. has released the eco-friendly AG100L Sinker EDM. The AG100L is part of Sodick's most popular line of Sinkers the AG Series. The AG100L features a simplified control mechanism which provides a direct link between the drive and the control. This ensures fast servo response time and optimal spark gaps at all times. The automatic three sided vertically sliding drop tank enables large workpieces to be easily loaded and unloaded. The AG100L has linear motor drives on the X, Y and Z axes, a 10-year positioning guarantee and glass scale feedback. The machine also comes standard with a zero electrode wear circuit and a fine finishing circuit. The AG100L has an X, Y, Z travel of 47.24" x 25.59" x 19.69" and can accommodate workpieces up to 11,000 lbs.
  • linear motor
    linear motor
