GF Machining Solutions announces the availability of its AgieCharmilles CUT C 350 and CUT C 600 wire EDMs for U.S. manufacturers that want high performance with low operating costs. At a $99,000 starting price point, the machines are not only cost-effective, but also provide optimized cutting speeds and reliable accuracy, while their AC CUT HMI 2 systems make for easy programming through efficient EDM expert modules.
Both the CUT C 350 and CUT C 600 offer manual mode setup for access to main functions that enable operators to perform manual measurements and machining. The machines feature low-maintenance designs that use minimal components and consumable parts to reduce operating costs. Along with an integrated anti-collision protection system, the machines include linear glass scales and encoders for high production accuracy.
Easily accessible wire spool holders allow for fast and easy changes, and standard automatic threading systems thread hard, soft, coated or uncoated wire for reliable lights-out manufacturing.
Both the CUT C 350 and CUT C 600 operate with digital Intelligent Power Generators (IPG) for optimized cutting speeds and feature several Expert Intelligent technologies to manage surface quality and part precision while they streamline overall operation. With IPG, the machines generate surface finishes of 0.25µm Ra in carbide and 0.30µm Ra in steel.
For wire breakage prevention on variable-height parts, the POWER-EXPERT intelligent function automatically selects optimal power levels. Corner-cutting strategies automatically adjust machining parameters during changes of cutting direction to create accurate sharp angles and small radii.
File and project management intelligent features on the CUT C 350 and CUT C 600 enable operators to configure and sequence jobs, follow job progress, manage digital project documents and access the AC CAM EASY programming system for autonomous operation.
- threading
threading
