Air-operated lift-magnet system
Eriez' air-operated lift-magnet system moves multiple parts or cutouts up and off of burn tables. It also can lift single sheets or plates up to 3" (76.2mm) thick from a stack to load a table. The system improves productivity and safety by eliminating manual handling of multiple parts and the need for operators to climb on burn tables, according to the company. Standard models have 24" (609.6mm), 48" (1,219.2mm) and 120" (3,048mm) designs to accommodate most common plate and sheet sizes.
