Air Turbine Tools details Drill Tap spindles for compact machining centers
Air Turbine Tools has highlighted pneumatic spindles in its Drill Tap Series for compact CNC machining centers. The company lists governed speeds of 30,000, 40,000, 50,000, 65,000 and 90,000 rpm across the range.
The spindles use a dry 90 psi air supply. The maker says the turbine governor increases airflow in response to load to help keep the tool close to its rated speed.
Applications listed by the company include milling, microdrilling, engraving and finishing with small tools. The release shows a spindle installation on a FANUC RoboDrill.
Edited by CTE Staff from a press release supplied by Air Turbine Tools.
