AccuteX’s new AL-600SA CNC Wire EDM is from Absolute Machine Tools. The AL-600SA moving-table model can be fully equipped with 6-axis capability, PCD cutting circuit, and AccuteX’s exclusive linear shaft motors that provide a 10-year positioning guarantee. These motors were designed and built fully in-house specifically for AccuteX wire EDMs. This concept ensures enhanced precision and performance with its maintenance-free design, 10 percent faster cutting, HIWIN linear guideways, 0.000004” Fagor glass scales and 64 bit processing.
S-cut fine finish skimming (9 Ra µin. surface finish), enhanced lead in/lead out control that eliminates witness marks at entry and exit points. Accuracy is achieved at +/-0.00012" (0.003 mm) and repeatability +/-0.00008" (0.002 mm). MST-II Micro Sparking Technology comes standard for surface finishes down to 5 Ra µin. in five passes.
The AL-600SAi comes standard with AccuteX’s patented fully annealing automatic wire threading (AWT) with the ability to perform submerged machining up to 11.81" (300mm) deep. Travels are 23.62” X-axis, 15.74” Y-axis, 11.81” Z-axis, and 3.94” U & V axes. Maximum workpiece size (XYZ) is 38.97” z 24.41” x 11.61” (990 mm x 621 mm x 295 mm) with a maximum workpiece weight of 2,450 lbs. (1,113 kg).
- annealing
annealing
Softening a metal by heating it to and holding it at a controlled temperature, then cooling it at a controlled rate. Also performed to produce simultaneously desired changes in other properties or in the microstructure. The purposes of such changes include improvement of machinability, facilitation of cold work, improvement of mechanical or electrical properties and increase in stability of dimensions. Types of annealing include blue, black, box, bright, full, intermediate, isothermal, quench and recrystallization.
- polycrystalline diamond ( PCD)
- threading
threading
- wire EDM
wire EDM
