AMSAW Sawing Machines
AMSAW high-speed, production saw machines from Advanced Machine & Engineering are specifically designed to use carbide blades to improve the cutting speed of ferrous and non-ferrous material, bars or billets, rails, profiles, pipes and tubes.
Standard design features include:
- Highly compact, rigid design
- Hardened spindle gears ground for minimum backlash
- Special saw blade guide and dampening device for accurate cutting to stabilize the blade and prolong tool life
- Low maintenance design
- Dry operation — no coolant needed
- Saw blade changeover in less than 3 minutes
- Double and triple measurement strokes for extra length cuts
- Fast, dependable chip disposal
Options include: stock size measuring, automated length measuring systems, bar manipulating systems, infeed and outfeed systems and stackers.
