Angular Contact and Radial Ball Bearings
Machine bearings define the load carrying capacity, speed, precision and performance of equipment. The quality of high-precision bearings is critical for success. GMN has been in the bearing business since 1908 and understands the demands equipment places on high-precision bearings.
See how the company's high-quality products, expert-level support and rapid response times allow GMN to lead the market in high precision bearings.
GMN's angular contact ball bearings carry both radial and axial loads transferred from one ring to the other along a specific contact angle.
Available angular contact bearing options:
- Ball Material: 52100 Bearing Steel or Silicon Nitride (Si3N4)
- Contact Angles: 15°(C) or 25°(E) (or custom, if needed)
- Pre-load: Spring or Rigid (or custom, if needed)
- Seals
- Lubrication: Grease, Oil or Dry
GMN has a large inventory in stock in Houston available to meet your machine needs.
GMN's radial ball bearing carry axial loads in both directions and have a contact angle of approximately 8°.
Available radial ball bearing options:
- Internal Clearance Options: C2 CN C3 C4 C5
- Shields
- Other customizations are also available
Reduce wear and tear on equipment with high-quality, super precision angular contact or radial ball bearings
