Aries NGP Tool Grinder
May 17, 2016
The latest addition to the extensive machine offering from Schneeberger, the new Aries NGP answers to the need for an affordable tool grinder with all the power of a big machine. Aries NGP offers almost 10-hp, duty-rated power with a direct-drive, double-ended spindle and the accuracy of HSK 50 wheel arbor interface.
The machine has been designed to fit even in the smallest space, barely 3' wide and just over 5' deep, the machine offers a 10”x10” work envelope, integrated coolant and is powered by Schneeberger Quinto Qg1 software, a CAD tool programing software that creates tool programs in seconds. All this made possible by the reliability and accuracy of the FANUC 31 series control.
  • arbor
    arbor
  • coolant
  • work envelope
    work envelope
PRODUCTS
11/20/2024
10/23/2024
10/23/2024
