AT9530 Coated Cermet Grade
Tungaloy is introducing a coated cermet grade, AT9530 for steel turning applications. The new AT9530 grade incorporates Tungaloy's unique multi-layered coating technology and special post-surface treatment PremiumTec. This combination provides superior resistance to wear and fracture for improved productivity in finishing of steel during high speed machining.
The grade offers remarkable wear resistance particularly in alloy steel turning, thus making it the first choice grade for that material application range. This latest addition complements the existing NS9530 and GT9530 cermet grades to enhance their application ranges and productivity.
The new AT9530 grade is available with the –TSF and –PS style chipbreakers, the first choice chipbreakers for steel turning, in standard ISO turning inserts as well as ISO-EcoTurn inserts. A total of 111 items are introduced to cover a range of applications.
Grade at a glance:
Well-balanced wear and fracture resistance thanks to special multi-layered (Ti,Al)N based coating
PremiumTec special post-surface treatment technology for machining stability
