Gravograph offers an Automatic Plate Feeder (APF) accessory that increases the productivity of Gravograph LS100, LS100EX, IS400, M40 laser and rotary engraving marking systems.
Simple hardware and plug and play features make for easy installation. This lightweight APF can hold from 195 up to 312 plates, depending on material thickness. Plates and tags can range in size and shape up to 4.7" x 3.9".
Except for plate loading and unloading, there is minimum operator interaction. Once programmed, the plates automatically move into marking position, are engraved, then ejected for out processing. The APF is quickly removed and stored when not in use.
