Ball-Grip Chucks
Ball-Grip Chucks
Ball-Grip chucks are used for first operation roughing and/or second operation finishing. The basic chuck is modified to suit machine mounting, the need for coolant and/or air through, and mounting for top tooling, which is designed to a customer's part and machining requirements.
Ball-Grip chucks are used for first operation roughing and/or second operation finishing. The basic chuck is modified to suit machine mounting, the need for coolant and/or air through, and mounting for top tooling, which is designed to a customer's part and machining requirements. Ball-Grip chucks are available in standard sizes up to 33″ (838.2mm) and special sizes up to 79″ (2m). Larger sizes available upon request.
Basic Standard Style Options:
- Two-, Three-, Four- and Six-Jaw Chucks
- Internal and External Chucking
- Centralizing, Compensating, Centralizing-Compensating, and Equalizing/Centralizing chucking mode.
Standard Features:
- Pull Down or Pull-Back Action – Assist in providing positive location against work stop.
- Jaw Swivel (Homing) – Jaw compensates for part variation insuring 2 point contact with each jaw.
- Jaw Travel – Increased jaw travel enhances part loading and tolerance variations.
- Sealed Design – Sealed slides significantly reduce costly maintenance and resulting down time.
- Ball Joint Construction – Power mechanism operates within a sealed unit of high pressure lubricant.
- High Power Ratio – Higher gripping force with less input resulting in longer chuck life.
- Differential Chucking – Chuck allows for High-Low pressure chucking.
Optional Features:
- Coolant- and/or Air-through center bore.
- Quick-change External/Internal chucking available for two and three jaw chucks.
- Quick change Jaw Mounting for rapidly changing work piece tooling.
- "W" series Platform style Jaw Mounting available to mount customers existing tooling.
- Counter Centrifugal option counteracts the negative effect of centrifugal force to accommodate high-speed applications.
