Ballscrew/Spline BNS-V
August 29, 2018
THK’s latest ballscrew/spline BNS-V features a compact and lightweight structure. The low inertia BNS-V enables quick starts and stops during high-speed operation.
The BNS-V is a stroke/rotary unit with ballscrew grooves and a ball spline groove that cross one another on a single shaft. The nuts of the ballscrew and the ball spline have dedicated support bearings directly embedded on the circumference of the nuts. Some advantages of the new ballscrew/spline BNS-V include a highly rigid shaft support, an angular-contact structure for highly accurate positioning and smooth motion with low noise.
The BNS-V is a downsized version of THK’s popular ballscrew/spline BNS-A. The BNS-V features a compact 72mm outer diameter, a low weight of 1.00kg and a low inertia of 2.00kg•cm2, contrasted with the BNS-A 86mm outer diameter, weight of 1.67kg and inertia of 4.32kg•cm2.
  • outer diameter ( OD)
PRODUCTS
11/20/2024
10/23/2024
10/23/2024
