Barriquan Deburring Toolholders
Sugino Corp. introduces the new Barriquan family of self-compensating deburring toolholders. Barriquan toolholders have integral tension and compression designed for hard tool deburring of all materials and part shapes.
March 8, 2016
Sugino Corp. introduces the new Barriquan family of self-compensating deburring toolholders. Barriquan toolholders have integral tension and compression designed for hard tool deburring of all materials and part shapes. A spring load within the tool generates constant pressure on the part to produce a uniform deburred surface.
They can be mounted in most machining centers, turning machines, Sugino drilling units or utilized as end-of-arm tooling on a robot. Standard industrial burr bits and brushes available from many sources can be utilized in the Barriquan Tools.
Barriquan Tool Holders are available for sale through Sugino's component drilling unit and burnishing tool distributors.
  • burnishing
    Finishing method by means of compressing or cold-working the workpiece surface with carbide rollers called burnishing rolls or burnishers.
