BC8100 PCBN-Grade Inserts
Mitsubishi Materials announces the expansion of BC8110 coated PCBN grade for high-hardened steel turning.
Technical Information:
• 38 new inserts to include positive style and negative style inserts.
• Honing styles include FS2-FS3 and GS2-GS3 for optimal performance.
• Longer tool life with PVD coating, when turning hardened steels.
• Coated with a new TiAlSiN technology for excellent wear resistance.
• The Ultra Micro-particle binder in the body is designed to prevent sudden fracture.
• Optimized cBN grain size and cBN content increases wear resistance and edge toughness.
Applications to Target:
• Best used with hardened steel.
• Covers the wide application range for continuous cutting of hardened steel.
• A variety of hones to maximize efficiency and tool life performance.
Benefits:
• TiAlSiN technology prevents coating exfoliation to reduce unusual wear.
• Can be used with and without coolant.
  • coolant
  • cubic boron nitride ( CBN)
  • physical vapor deposition ( PVD)
  • polycrystalline cubic boron nitride ( PCBN)
    Cutting tool material consisting of polycrystalline cubic boron nitride with a metallic or ceramic binder. PCBN is available either as a tip brazed to a carbide insert carrier or as a solid insert. Primarily used for cutting hardened ferrous alloys.
  • turning
  • wear resistance
    wear resistance
