![Beam Splitters for Lasers for 100 Watts Up Beam Splitters for Lasers](/sites/default/files/styles/product_image/public/product_images/15861%20Laser%20Research.jpg?itok=KRfVEaOD)
A line of beam splitters for lasers from 100 Watts up that are designed for use at 45 degree angle of incidence and 10.6 microns has been introduced by Laser Research Optics.
Laser Research Beam Splitters for 100 Watt lasers and up are designed for use at 45 degree angle of incidence and 10.6 microns wavelength. Made from ZnSe with S or P polarization coatings to modify their reflectance, they are marked with an arrow on the OD surface pointing towards surface “1.”
Offered in 3/4” to 3” OD sizes and various thicknesses, Laser Research Beam Splitters are coated on surface “1” 50% ±3% reflectance and surface “2” has an anti-reflectance coat for 0.25% max. reflectance. Parallelism is 3 Arc minutes max., surface finish is 40-20 scratch-dig per MIL-O-13830, and flatness is 1/40 wave max. at 10.6 microns.
- outer diameter ( OD)
