Pioneer N.A. has released its new Big Bore 800mm rotary table, starting at $76,000 with 11,572 ft./lbs. of brake torque, 800mm OD and a large 450mm (17.7") ID through-hole. Designed for vertical and horizontal applications, long life and easy maintenance, according to the company. Professional installation services are available, as well as a complete offering of rotary tables for all applications.
- inner diameter ( ID)
- outer diameter ( OD)
- through-hole
through-hole
