![BK-1 Mini PRESTO BLACK Finishing Line for Iron and Steel Parts BK-1 Mini PRESTO BLACK Finishing Line](/sites/default/files/styles/product_image/public/product_images/Birchwood0418.jpg?itok=w4hhFagL)
Now there’s a better way to protect small quantities of iron and steel parts from corrosion with Birchwood Technologies’ BK-1 Mini PRESTO BLACK finishing line. It’s fast, easy and economical.
The BK-1 line is a low-cost alternative and/or substitute for large scale finishing. This mini PRESTO BLACK room temperature blackening system for iron and steel from Birchwood Technologies is great for small production operations which require robust corrosion resistance and galling protection on critical surfaces. All types of parts, from machine components to metal stampings and more, are great candidates for this PRESTO BLACK process.
Many manufacturers prefer PRESTO BLACK over the hot oxide method. It’s a 15-minute process that eliminates the hazards of hot oxide by operating at room temperature. It provides high corrosion resistance tested for up to 800 hours humidity exposure when sealed with an appropriate rust preventive.
Most important, the PRESTO BLACK process produces a virtually nondimensional coating of less than 0.5 micron thickness. It is ideally suited for components requiring a black finish for visual appeal as well as rust protection.
The PRESTO BLACK BK-1 system contains seven tanks and covers, hot-plate (for heated cleaner), plus all the chemicals needed to operate a 5-gal. blackening line. This includes 1 gallon of Presto Black MKP, 1 gallon of Presto Black RPL, 5 gallons of Dri-Touch Plus IRP3 water displacing sealant and easy-to-follow instructions.
- corrosion resistance
- galling
galling
Condition whereby excessive friction between high spots results in localized welding with subsequent spalling and further roughening of the rubbing surface(s) of one or both of two mating parts.
- micron
micron
Measure of length that is equal to one-millionth of a meter.
