YG-1 announced its latest promotion on its world-renowned Blue Ring Tap lineup. The promotion features 28 individual tap bundles, including spiral-flute and spiral-point taps in inch and metric sizes.
According to Mark Ford, director of product management holemaking and threading, “The bundles offer shop owners and machinists three significant ways to save time and money. Number one—lower cost per hole through optimized geometry and YG-1’s exclusive Hardslick Coating that also provides longer tool life. Second, higher productivity in HSS-PM material through smooth chip evacuation and the tap’s ability to handle greater spindle speeds. And finally more value. Each kit in all configurations, features a free carbide Dream Drill, sized for the taps provided in each bundle.”
All tap bundles come conveniently packaged as a six-pack in a durable foam-mounted display cup. “This promotion is definitely a win-win for our customer—legendary Blue Ring Tap performance and a free Dream Drill—all at very attractive bundle price,” Ford said.
- tap
tap
- threading
threading
