BlueFire Fiber Discs
Norton Abrasives has introduced Norton NorZon BlueFire F826 Fiber Discs for the metal fabricating industry.
February 1, 2011
Norton Abrasives has introduced Norton NorZon BlueFire F826 Fiber Discs for the metal fabricating industry. NorZon BlueFire fiber discs are positioned as Norton's "better" choice for stainless, super alloys, steel cast iron and high pressure applications.
BlueFire features a new and improved blend of patented zirconia alumina and ceramic alumina abrasive, which has a unique micro fracturing capability that allows a constant supply of new cutting edges for fast, aggressive cutting that self-sharpens with use.
BlueFire F826 is also available as a Speed-Change fiber disc featuring Norton's quick, tool-free, twist-on and off Speed-Change fasteners. Available in 5" to 7" sizes with grit ranges from 25 to 60, Speed-Change discs lock to standard back-up pads with a unique nut design and are easily removed for increased productivity.
The BlueFire F826 AVOS (allows view of surface) discs feature a patented see-through design that allows uninterrupted cutting, reducing heat up to 30 percent over standard discs. The scooped holes create air flow to pull swarf away from the grinding zone, which cools cutting and extends product life. A five degree angle back-up pad allows greater utilization of the disc surface and prevents gouging of the workpiece.
