BlueFire Grinding Wheels
Norton is implementing a performance upgrade across their "Better" tier of metal fabricating abrasives products for portable grinding applications. Products in the tier will now be sub-branded as Norton BlueFire and feature a zirconia alumina grain with properties that enable significantly improved performance.
April 12, 2012
"Our new generation NorZon grain has been tested across many product lines and has consistently resulted in performance improvements of up to 30 percent compared to the previous NorZon product," said David Long, Director of Marketing and Strategy at Norton Abrasives.
Currently Norton "Better" fiber discs, flap discs, coated abrasive belts and portable wheels, cones and plugs have been upgraded to the new grain. In addition, current Charger depressed center and cut-off wheels and NorZon paper discs, non-woven wheels and quick-change discs for portable grinding applications will be upgraded to the new grain over the next several months. All upgraded products will be unified under the Norton BlueFire brand, designating their "Better" tier abrasive products for the entire metal fabricating offering.
  • coated abrasive
    Flexible-backed abrasive. Grit is attached to paper, fiber, cloth or film. Types include sheets, belts, flap wheels and discs.
