BNC2000 Series CBN Grades
July 27, 2016
Sumitomo’s new BNC2000 series CBN grades perform with exceptional accuracy and productivity. The BNC2010 grade is designed for high precision hard turning. A newly developed CBN substrate coated with a TiCN layer achieves excellent surface finish, while reducing wear.
The high efficiency BNC2020 Grade is designed for general hardened steel machining. Featuring a newly developed tough CBN substrate coated with a highly wear-resistant TiAlN layer it achieves more stable machining and a longer tool life.
  • cubic boron nitride ( CBN)
  • hard turning
    hard turning
  • titanium aluminum nitride ( TiAlN)
    Often used as a tool coating. AlTiN indicates the aluminum content is greater than the titanium. See coated tools.
  • titanium carbonitride ( TiCN)
    Often used as a tool coating. See coated tools.
  • turning
