Bore and Snap Gages
Bore and Snap Gages
TESA management recently discontinued production of its Brown & Sharpe Standard bore and snap gages. Mahr Federal bore and snap gages are available to replace these TESA products.
February 1, 2015
TESA management recently discontinued production of its Brown & Sharpe Standard bore and snap gages. Mahr Federal bore and snap gages are available to replace these TESA products. They allow users to upgrade performance with integrated wireless data transmission. Replacement gages include Mahr Federal 1280 P and 844 N adjustable bore gages, along with 300 P snap gages.
Mahr Federal 1280 P adjustable bore gages feature rugged construction for long life and low maintenance, including a stainless steel gaging head and one piece centralizing yoke with replaceable tungsten carbide balls. Furnished with either a dial or digital indicator and available with integrated wireless data transmitters, 1280 P bore gages are sized to measure diameters from 12 — 200mm (0.50 — 8") with extensions, and depths from 76 — 1220mm (3 — 48").
Also available with integrated wireless transmission, Mahr Federal's precision self-centering 844 N adjustable bore gages are virtually impervious to temperature changes as both the shank and transfer rod are made from Invar steel. Extremely versatile and quick to adjust to any size within their range, 844 N bore gages can be used to measure diameter, roundness, and conical form, as well as the distances of plane-parallel surfaces of tight tolerance parts. Able to measure diameters from 18 — 800mm (0.7 — 32"), they provide low hysteresis and high repeatability.
Mahr Federal 300 P snap gages provide fast precise OD measurement on the shop floor. Available over a wide range of sizes, styles and readout configurations, they provide measuring capacity from 0 — 508mm (0 — 20") and are available with integrated wireless transmitters and dial or digital indicators. A unique "Channel Lock" design assures precisely parallel anvil surfaces, with positive position locking at any point within the range.
