To maximize the full benefit of recent advances in machine tool designs, Chevin Tools Inc. has developed a new range of boring bar, turning and blade toolholders (parting and grooving applications). Delivering high-pressure coolant directly through the cutting tip of static tools enables significant improvements in cutting efficiency and improves production.
- boring
boring
- boring bar
boring bar
Essentially a cantilever beam that holds one or more cutting tools in position during a boring operation. Can be held stationary and moved axially while the workpiece revolves around it, or revolved and moved axially while the workpiece is held stationary, or a combination of these actions. Installed on milling, drilling and boring machines, as well as lathes and machining centers.
- coolant
- grooving
grooving
- turning
