A Brand AE-CR-MS-H End Mill
The A Brand AE-CR-MS-H end mill offers the following features & benefits: Variable index to reduce chattering. Cutting edge geometry for stable machining of high-hardness steels. DUROREY coating which allows for outstanding performance in high-hardness steels
January 12, 2023
OSG is pleased to announce that inch sizes have been added to the A Brand AE-CR-MS-H End Mill offering! The A Brand AE-CR-MS-H is a multi-flute square type and radius type carbide end mill designed for stable and high-efficiency milling of high-hardness steels. With the addition of the new DUROREY coating uniquely engineered for high-hardness steels, high chipping resistance is made possible even in work materials exceeding 60 HRC, allowing long tool life and high speed milling.
The following list numbers are associated with the NEW A Brand AE-CR-MS-H series:
  • NEW! List #8470 A Brand AE-CR-MS-H (inch)
  • Variable index to reduce chattering
  • Cutting edge geometry for stable machining of high-hardness steels
  • DUROREY coating which allows for outstanding performance in high-hardness steels
