![Brass Pie Jaws Brass Pie Jaws Hold Delicate Materials Securely Without Marring or Distortion](/sites/default/files/styles/product_image/public/product_images/Brass%20Pie%20Jaws%204.jpg?itok=PVve2i3M)
Dillon Manufacturing presents brass pie jaws which firmly grip delicate workpieces without marring or distortion. Maximum contact area from the full grip jaws provides a solid gripping surface which yields more friction for drive with reduced part distortion, while the brass provides a softer surface without marring or marking of the workpiece surface. Standard parts available to 32-inches in diameter with custom designs available with special heights, diameters, and configurations, including a matching serration location which is exactly perpendicular to the slots. Ideal for components fabricated from brass, aluminum, bronze, and other softer, malleable alloys.
Dillon full-grip chuck jaws are made in the USA with industry-leading lead-times. They are ideal for high-speed machining, as well as precision boring, tapping, drilling, and finishing across virtually all industrial markets. In addition to brass, Dillon Full Grip Pie Jaws are available in 6061 aluminum, 1018 steel and cast iron.
These wrap-around type top jaws distribute more of the gripping pressure across the workpiece, reducing part distortion. Dillon standard and custom full-grip jaws are available in serrated, tongue & groove serrated, Acme serrated, and square serrated designs.
- alloys
alloys
- boring
boring
- chuck
chuck
- tapping
tapping
