The C 1800H heavy-duty CNC Lathe from Romi is ideal for machining very large steel parts and components. Weighing in at 97,000 lbs., the lathe features a distance between centers from 157 to 394 inches, a 47-inch swing over cross slide, and a max weight capacity between centers of 66,100 lbs. at 50 rpm. The bed width and height are 55 inches and 30 inches, respectively.
Romi's C 1800H is part of the company's C series heavy-duty flatbed CNC lathes. Each model is built with Romi-made monoblock cast iron beds with hardened and ground guideways for optimum rigidity, accuracy, and performance. The C1800H features a 114 hp main motor and a geared A2-20" headstock with Timken precision bearings. It has a robust tailstock with thrust force monitoring and compensation system.
All critical components used to build Romi machine tools are designed and built in-house for complete control and manufacturing quality assurance. Each innovative Romi machine tool is designed and manufactured based on extensive customer research and feedback. This customer-centric approach to design allows Romi machine tool owners to innovate, grow and gain a competitive advantage.
- centers
centers
- lathe
lathe
- quality assurance ( quality control)
