Carbide Thread Mills
Niagara Cutter Inc. says its carbide thread mills provide high-quality threads, increase productivity and perform consistently. The tools are available in a range of thread sizes and diameters and with several features, including an AlCrN coating, extended-reach capability and through-coolant. The company also offers CVD diamond-coated thread mills for threading composite materials.
  • chemical vapor deposition ( CVD)
  • threading
    threading
